Motor Specs & Circuit Diagram
I'm an Aero student with virtually no electronics knowledge. I'm trying to figure out what value resistor to add to this circuit, so my motor provides the correct amount of power.
The motor is usually part of a small quadcopter drone. The battery used is 3.7 V, 650 mAh. When this battery was powering the whole drone (lights, 4 motors etc) the meter readings from a single motor at full power were 3.203 V and 1.88 A.
I have now separated one motor in order to build the simple circuit (pictured) just to measure RPM. (This is a very small part of my project. I am aware of more sophisticated methods to vary motor output, but I am using a variable resistor as the results only need to be rough). This circuit will use the same battery as before.
I would like to add a resistor to this circuit, so that when the variable resistor is turned to zero, the motor cannot output any more power than it was before. Then, when the variable resistor is increased, it eventually stops the motor.
My question is: What values of resistance do this normal and variable resistor have to be?
