I am looking for some information on how to measure the current output of a power supply that I took out of an old DVD player. On the PCB there are multiple outputs from 3.3V to 24V, but it doesn't mention anything about the current rating/output.
Basically I need to drive four 12V motors each with a current rating of 400mA, so presumably I need no less than 1.6A output?
Anyone know how to measure the current capabilities of this PSU?
Thanks D
Well the suitable way would be to have the PSU connected to the old DVD player innards so that its normal operational load could be running. You would then simply insert a current meter (DMM in current measure mode) in series with one output at a time and monitor the current consumption into the normal load. This will give a good picture of that that power supply was nomimally expected to deliver.
If the "old DVD player" is junked out and not available to be used for a nominal load then you have a harder job on your hands. One method to determine capability of the supply would be to put the thing on the test bench and connect resistor loads to the outputs. You want to utilize high wattage resistors for this so that they do not get hot and cause a change in the reistance of these load resistors. For this type of test you will need to simultaneously load all the outputs that you would like to use on the PSU. The idea is to start with relatively light loads and then interatively increase the loads to more and more current while monitoring the output voltage across each resistor and periodicaly checking the temperature of critical components on the PSU board. As you get to heavier loads it also pays to check each output with an oscilloscope to check each output for amount of noise and ripple.
When you reach load sizes that start to cause the PSU to get hotter than a nominal working value, increased ripple beyond more than 1 or 2% of the voltage levels of the output, or the nominal output voltage sags more than 4 to 5% then you know you are reaching the design limits of the power supply. From this check the current flow into each load resistor and you will have a close idea of the supply capacity.
For sustained usage of the supply it is recommemded to back off on the limits determined above. Also make sure to use the PSU in no worse enclosue space than it was in when in the DVD player. For exwmple if the original application had a fan blowing air over the PSU then make sure to provide as good or better environment in the re-use application.
Without a schematic or a parts list, there is no definitive way of determining how much current a supply salvaged from old equipment can deliver. You can try to determine the part numbers of such components as the power transformer, rectifier diodes, voltage regulators, etc. and look up their specifications but this will only give an indication of how much current the supply was designed for. For your application, I would suggest first measuring the output voltage of the 12 volt output (assuming there is one) and then connecting one of your motors to it. Measure the output voltage again. Note how much the voltage drops and observe the motor for a period of about one hour. Note if any components of the supply seem to be getting hot (be careful not to get burned). If all looks good (the voltage doesn't drop by more than 0.5 volt or so and nothing gets too hot), try connecting another motor. Repeat this process until all 4 motors are running. One hour should be long enough for all of the components to reach their equilibrium temperatures. How much the output voltage can drop and still run your motors is a function of the motors but I would assume that if the voltage drops below 11 volts, the supply is probably not adequate. If the supply passes this test, then it is probably OK to use. But, again, there are no guarantees when using salvaged equipment with no documentation. Good Luck.
    \$\begingroup\$ Keep in mind that DC motor starting current can be 10x or more nominal running current. While the proposed test would determine if the PSU can hold up 4 running motors, the way that they are started/stopped ( All at once? One at a time?) may still prove the supply to be inadequate for the application. \$\endgroup\$
    – HikeOnPast
    Commented Nov 8, 2012 at 4:56
  • \$\begingroup\$ Thanks, interesting point! My motors are actually stepper motors driven from a Sparkfun QuadStepper board. \$\endgroup\$
    – Dec
    Commented Nov 8, 2012 at 13:30
