I soldered an SMD LED (that cost $55) to the board by setting the aluminum board on a kitchen skillet that was heating up. I did my best to control the heat. It usually takes only a minute of heat and the LED sinks down, and I pick it up out of the skillet immediately thereafter.
This time, unfortunately it took a few tries before I got it right. Upon testing my LED, at first it worked, but after only 5 minutes of testing, it was flickering and then finally stopped shining.
The datasheet says it can be reflow soldered up to 5 times, the max time for max soldering temp is around 50 seconds. I don't have a reflow soldering system. I don't think I went too over the soldering time, if I did go over at all.
Was it my solder job that caused this LED's demise? What can I do differently now that I've ordered another damn $55 LED?
