I have following PCB design, which use PIC32MZ2048EFH144 and KSZ8081RNACA, I want to set up phy address to be 3.
From document it has following words "Config Mode: The pull-up/pull-down value is latched as PHYAD[1:0] at the de-assertion of reset.",
which can be found at following link: https://docs.rs-online.com/583f/0900766b8141ed48.pdf
How to get into config mode?
What are the steps to configure this chip?
Thanks
