I'm trying to capture a digital signal that consists of 8us HIGH pulses with 8us or 16us LOW pauses in between. There are additional LOW pauses of about 6ms (yes, ms) that separate data frames.
I'm looking to measure the time between rising edges, so I need to measure 16us and 24us intervals while not tripping over those 6000us pauses.
My first attempt was using the Arduino API attachInterupt in RISING mode, then getting the time with micros() in the ISR. That worked somewhat, but also produced lots of wrong data, probably due to interrupt latency. The CPU is also drawing a bit on the display over SPI, not sure if that matters.
As this looks like a good use case for Timer Input Capture, I'm now trying to use the Capture facility of MCPWM. The counter is clocked at 80MHz, which should be plenty of resolution. This is what I have so far:
namespace pins { enum
  pxx = 17,
volatile int measure[2];
static void IRAM_ATTR pxxIsr(void*)
  static uint32_t lastTime;
  auto now = mcpwm_capture_signal_get_value(MCPWM_UNIT_1, MCPWM_SELECT_CAP1);
  auto dt = now - lastTime;
  lastTime = now;
  measure[0] = dt;
  ++measure[1];
  MCPWM1.int_clr.val = CAP1_INT_EN;
void setup()
  mcpwm_gpio_init(MCPWM_UNIT_1, MCPWM_CAP_1, pins::pxx);
  gpio_pulldown_en((gpio_num_t)pins::pxx);
  mcpwm_capture_enable(MCPWM_UNIT_1, MCPWM_SELECT_CAP1, MCPWM_POS_EDGE, 80); // prescale by 80 to directly count us
  mcpwm_isr_register(MCPWM_UNIT_1, pxxIsr, nullptr, ESP_INTR_FLAG_IRAM, nullptr);
  MCPWM1.int_ena.val = CAP1_INT_EN;
The ISR is a bit condensed above, but that's all it does at the moment. measure[1] increases rapidly while the signal is connected to the pin, so I know the interrupt is working. measure[0] however is zero most of the time, with the occasional 6-digit number.
  • \$\begingroup\$ Can you pre-load this ESP32 counter value before enabling mcpwm_isr? If so, then you can look for two interrupts: one for mcpwm to get its valid capture value, and the other interrupt where the counter overflows. You set up the pre-load value so that it overflows during those l-o-n-g 6ms periods. The overflow interrupt would be used to invalidate the current mcpwm measurement, and possibly start another. \$\endgroup\$
    – glen_geek
    Sep 2, 2020 at 15:11
  • \$\begingroup\$ not sure how that would help. If I understand the prescaler right, it should overflow every 71.5 hours. Its never been running that long. And even if the counter overflows (once), then the - also overflows, giving me the correct answer. The problem is that I seem to be getting the same value most of the time, which gives me a zero difference. \$\endgroup\$
    – kiw
    Sep 2, 2020 at 16:13
    /* MCPWM basic config example
   This example code is in the Public Domain (or CC0 licensed, at your option.)
   Unless required by applicable law or agreed to in writing, this
   software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
   CONDITIONS OF ANY KIND, either express or implied.
 * This example will show you how to use each submodule of MCPWM unit.
 * The example can't be used without modifying the code first.
 * Edit the macros at the top of mcpwm_example_basic_config.c to enable/disable the submodules which are used in the example.
#include <stdio.h>
#include "string.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/queue.h"
#include "esp_attr.h"
#include "soc/rtc.h"
#include "driver/mcpwm.h"
#include "soc/mcpwm_periph.h"
#define MCPWM_EN_CARRIER 0   //Make this 1 to test carrier submodule of mcpwm, set high frequency carrier parameters
#define MCPWM_EN_DEADTIME 0  //Make this 1 to test deadtime submodule of mcpwm, set deadtime value and deadtime mode
#define MCPWM_EN_FAULT 0     //Make this 1 to test fault submodule of mcpwm, set action on MCPWM signal on fault occurence like overcurrent, overvoltage, etc
#define MCPWM_EN_SYNC 0      //Make this 1 to test sync submodule of mcpwm, sync timer signals
#define MCPWM_EN_CAPTURE 0   //Make this 1 to test capture submodule of mcpwm, measure time between rising/falling edge of captured signal
#define MCPWM_GPIO_INIT 0    //select which function to use to initialize gpio signals
#define CAP_SIG_NUM 3   //Three capture signals
#define CAP0_INT_EN BIT(27)  //Capture 0 interrupt bit
#define CAP1_INT_EN BIT(28)  //Capture 1 interrupt bit
#define CAP2_INT_EN BIT(29)  //Capture 2 interrupt bit
#define GPIO_PWM0A_OUT 19   //Set GPIO 19 as PWM0A
#define GPIO_PWM0B_OUT 18   //Set GPIO 18 as PWM0B
#define GPIO_PWM1A_OUT 17   //Set GPIO 17 as PWM1A
#define GPIO_PWM1B_OUT 16   //Set GPIO 16 as PWM1B
#define GPIO_PWM2A_OUT 15   //Set GPIO 15 as PWM2A
#define GPIO_PWM2B_OUT 14   //Set GPIO 14 as PWM2B
#define GPIO_CAP0_IN   23   //Set GPIO 23 as  CAP0
#define GPIO_CAP1_IN   25   //Set GPIO 25 as  CAP1
#define GPIO_CAP2_IN   26   //Set GPIO 26 as  CAP2
#define GPIO_SYNC0_IN   2   //Set GPIO 02 as SYNC0
#define GPIO_SYNC1_IN   4   //Set GPIO 04 as SYNC1
#define GPIO_SYNC2_IN   5   //Set GPIO 05 as SYNC2
#define GPIO_FAULT0_IN 32   //Set GPIO 32 as FAULT0
#define GPIO_FAULT1_IN 34   //Set GPIO 34 as FAULT1
#define GPIO_FAULT2_IN 34   //Set GPIO 34 as FAULT2
typedef struct {
    uint32_t capture_signal;
    mcpwm_capture_signal_t sel_cap_signal;
} capture;
uint32_t *current_cap_value = NULL;
uint32_t *previous_cap_value = NULL;
xQueueHandle cap_queue;
#if MCPWM_EN_CAPTURE
static mcpwm_dev_t *MCPWM[2] = {&MCPWM0, &MCPWM1};
#endif
static void mcpwm_example_gpio_initialize(void)
    printf("initializing mcpwm gpio...\n");
#if MCPWM_GPIO_INIT
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, GPIO_PWM0A_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0B, GPIO_PWM0B_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM1A, GPIO_PWM1A_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM1B, GPIO_PWM1B_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM2A, GPIO_PWM2A_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM2B, GPIO_PWM2B_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_CAP_0, GPIO_CAP0_IN);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_CAP_1, GPIO_CAP1_IN);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_CAP_2, GPIO_CAP2_IN);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_SYNC_0, GPIO_SYNC0_IN);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_SYNC_1, GPIO_SYNC1_IN);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_SYNC_2, GPIO_SYNC2_IN);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_FAULT_0, GPIO_FAULT0_IN);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_FAULT_1, GPIO_FAULT1_IN);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_FAULT_2, GPIO_FAULT2_IN);
#else
    mcpwm_pin_config_t pin_config = {
        .mcpwm0a_out_num = GPIO_PWM0A_OUT,
        .mcpwm0b_out_num = GPIO_PWM0B_OUT,
        .mcpwm1a_out_num = GPIO_PWM1A_OUT,
        .mcpwm1b_out_num = GPIO_PWM1B_OUT,
        .mcpwm2a_out_num = GPIO_PWM2A_OUT,
        .mcpwm2b_out_num = GPIO_PWM2B_OUT,
        .mcpwm_sync0_in_num  = GPIO_SYNC0_IN,
        .mcpwm_sync1_in_num  = GPIO_SYNC1_IN,
        .mcpwm_sync2_in_num  = GPIO_SYNC2_IN,
        .mcpwm_fault0_in_num = GPIO_FAULT0_IN,
        .mcpwm_fault1_in_num = GPIO_FAULT1_IN,
        .mcpwm_fault2_in_num = GPIO_FAULT2_IN,
        .mcpwm_cap0_in_num   = GPIO_CAP0_IN,
        .mcpwm_cap1_in_num   = GPIO_CAP1_IN,
        .mcpwm_cap2_in_num   = GPIO_CAP2_IN
    mcpwm_set_pin(MCPWM_UNIT_0, &pin_config);
#endif
    gpio_pulldown_en(GPIO_CAP0_IN);    //Enable pull down on CAP0   signal
    gpio_pulldown_en(GPIO_CAP1_IN);    //Enable pull down on CAP1   signal
    gpio_pulldown_en(GPIO_CAP2_IN);    //Enable pull down on CAP2   signal
    gpio_pulldown_en(GPIO_SYNC0_IN);   //Enable pull down on SYNC0  signal
    gpio_pulldown_en(GPIO_SYNC1_IN);   //Enable pull down on SYNC1  signal
    gpio_pulldown_en(GPIO_SYNC2_IN);   //Enable pull down on SYNC2  signal
    gpio_pulldown_en(GPIO_FAULT0_IN);  //Enable pull down on FAULT0 signal
    gpio_pulldown_en(GPIO_FAULT1_IN);  //Enable pull down on FAULT1 signal
    gpio_pulldown_en(GPIO_FAULT2_IN);  //Enable pull down on FAULT2 signal
 * @brief Set gpio 12 as our test signal that generates high-low waveform continuously, connect this gpio to capture pin.
static void gpio_test_signal(void *arg)
    printf("intializing test signal...\n");
    gpio_config_t gp;
    gp.intr_type = GPIO_INTR_DISABLE;
    gp.mode = GPIO_MODE_OUTPUT;
    gp.pin_bit_mask = GPIO_SEL_12;
    gpio_config(&gp);
    while (1) {
        //here the period of test signal is 20ms
        gpio_set_level(GPIO_NUM_12, 1); //Set high
        vTaskDelay(10);             //delay of 10ms
        gpio_set_level(GPIO_NUM_12, 0); //Set low
 * @brief When interrupt occurs, we receive the counter value and display the time between two rising edge
static void disp_captured_signal(void *arg)
    capture evt;
    while (1) {
        xQueueReceive(cap_queue, &evt, portMAX_DELAY);
        if (evt.sel_cap_signal == MCPWM_SELECT_CAP0) {
            printf("CAP0 : %d us\n", evt.capture_signal);
        if (evt.sel_cap_signal == MCPWM_SELECT_CAP1) {
            printf("CAP1 : %d us\n", evt.capture_signal);
        if (evt.sel_cap_signal == MCPWM_SELECT_CAP2) {
            printf("CAP2 : %d us\n", evt.capture_signal);
 * @brief this is ISR handler function, here we check for interrupt that triggers rising edge on CAP0 signal and according take action
static void IRAM_ATTR isr_handler(void)
    uint32_t mcpwm_intr_status;
    capture evt;
    mcpwm_intr_status = MCPWM[MCPWM_UNIT_0]->int_st.val; //Read interrupt status
    //calculate the interval in the ISR,
    //so that the interval will be always correct even when cap_queue is not handled in time and overflow.
    if (mcpwm_intr_status & CAP0_INT_EN) { //Check for interrupt on rising edge on CAP0 signal
        current_cap_value[0] = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP0); //get capture signal counter value
        evt.capture_signal = (current_cap_value[0] - previous_cap_value[0]) / (rtc_clk_apb_freq_get() / 1000000);
        previous_cap_value[0] = current_cap_value[0];
        evt.sel_cap_signal = MCPWM_SELECT_CAP0;
        xQueueSendFromISR(cap_queue, &evt, NULL);
    if (mcpwm_intr_status & CAP1_INT_EN) { //Check for interrupt on rising edge on CAP0 signal
        current_cap_value[1] = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP1); //get capture signal counter value
        evt.capture_signal = (current_cap_value[1] - previous_cap_value[1]) / (rtc_clk_apb_freq_get() / 1000000);
        previous_cap_value[1] = current_cap_value[1];
        evt.sel_cap_signal = MCPWM_SELECT_CAP1;
    if (mcpwm_intr_status & CAP2_INT_EN) { //Check for interrupt on rising edge on CAP0 signal
        current_cap_value[2] = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP2); //get capture signal counter value
        evt.capture_signal = (current_cap_value[2] - previous_cap_value[2]) / (rtc_clk_apb_freq_get() / 1000000);
        previous_cap_value[2] = current_cap_value[2];
        evt.sel_cap_signal = MCPWM_SELECT_CAP2;
    MCPWM[MCPWM_UNIT_0]->int_clr.val = mcpwm_intr_status;
#endif
 * @brief Configure whole MCPWM module
static void mcpwm_example_config(void *arg)
    //1. mcpwm gpio initialization
    mcpwm_example_gpio_initialize();
    //2. initialize mcpwm configuration
    printf("Configuring Initial Parameters of mcpwm...\n");
    mcpwm_config_t pwm_config;
    pwm_config.frequency = 1000;    //frequency = 1000Hz
    pwm_config.cmpr_a = 60.0;       //duty cycle of PWMxA = 60.0%
    pwm_config.cmpr_b = 50.0;       //duty cycle of PWMxb = 50.0%
    pwm_config.counter_mode = MCPWM_UP_COUNTER;
    pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
    mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config);   //Configure PWM0A & PWM0B with above settings
    pwm_config.frequency = 500;     //frequency = 500Hz
    pwm_config.cmpr_a = 45.9;       //duty cycle of PWMxA = 45.9%
    pwm_config.cmpr_b = 7.0;    //duty cycle of PWMxb = 07.0%
    mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_1, &pwm_config);   //Configure PWM1A & PWM1B with above settings
    pwm_config.frequency = 400;     //frequency = 400Hz
    pwm_config.cmpr_a = 23.2;       //duty cycle of PWMxA = 23.2%
    pwm_config.cmpr_b = 97.0;       //duty cycle of PWMxb = 97.0%
    pwm_config.counter_mode = MCPWM_UP_DOWN_COUNTER; //frequency is half when up down count mode is set i.e. SYMMETRIC PWM
    pwm_config.duty_mode = MCPWM_DUTY_MODE_1;
    mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_2, &pwm_config);   //Configure PWM2A & PWM2B with above settings
#if MCPWM_EN_CARRIER
    //3. carrier configuration
    //comment if you don't want to use carrier mode
    //in carrier mode very high frequency carrier signal is generated at mcpwm high level signal
    mcpwm_carrier_config_t chop_config;
    chop_config.carrier_period = 6;         //carrier period = (6 + 1)*800ns
    chop_config.carrier_duty = 3;           //carrier duty = (3)*12.5%
    chop_config.carrier_os_mode = MCPWM_ONESHOT_MODE_EN; //If one shot mode is enabled then set pulse width, if disabled no need to set pulse width
    chop_config.pulse_width_in_os = 3;      //first pulse width = (3 + 1)*carrier_period
    chop_config.carrier_ivt_mode = MCPWM_CARRIER_OUT_IVT_EN; //output signal inversion enable
    mcpwm_carrier_init(MCPWM_UNIT_0, MCPWM_TIMER_2, &chop_config);  //Enable carrier on PWM2A and PWM2B with above settings
    //use mcpwm_carrier_disable function to disable carrier on mcpwm timer on which it was enabled
#endif
#if MCPWM_EN_DEADTIME
    //4. deadtime configuration
    //comment if you don't want to use deadtime submodule
    //add rising edge delay or falling edge delay. There are 8 different types, each explained in mcpwm_deadtime_type_t in mcpwm.h
    mcpwm_deadtime_enable(MCPWM_UNIT_0, MCPWM_TIMER_2, MCPWM_BYPASS_FED, 1000, 1000);   //Enable deadtime on PWM2A and PWM2B with red = (1000)*100ns on PWM2A
    mcpwm_deadtime_enable(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_BYPASS_RED, 300, 2000);        //Enable deadtime on PWM1A and PWM1B with fed = (2000)*100ns on PWM1B
    mcpwm_deadtime_enable(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_ACTIVE_RED_FED_FROM_PWMXA, 656, 67);  //Enable deadtime on PWM0A and PWM0B with red = (656)*100ns & fed = (67)*100ns on PWM0A and PWM0B generated from PWM0A
    //use mcpwm_deadtime_disable function to disable deadtime on mcpwm timer on which it was enabled
#endif
#if MCPWM_EN_FAULT
    //5. enable fault condition
    //comment if you don't want to use fault submodule, also u can comment the fault gpio signals
    //whenever fault occurs you can configure mcpwm signal to either force low, force high or toggle.
    //in cycmode, as soon as fault condition is over, the mcpwm signal is resumed, whereas in oneshot mode you need to reset.
    mcpwm_fault_init(MCPWM_UNIT_0, MCPWM_HIGH_LEVEL_TGR, MCPWM_SELECT_F0); //Enable FAULT, when high level occurs on FAULT0 signal
    mcpwm_fault_init(MCPWM_UNIT_0, MCPWM_HIGH_LEVEL_TGR, MCPWM_SELECT_F1); //Enable FAULT, when high level occurs on FAULT1 signal
    mcpwm_fault_init(MCPWM_UNIT_0, MCPWM_HIGH_LEVEL_TGR, MCPWM_SELECT_F2); //Enable FAULT, when high level occurs on FAULT2 signal
    mcpwm_fault_set_oneshot_mode(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_SELECT_F0, MCPWM_FORCE_MCPWMXA_HIGH, MCPWM_FORCE_MCPWMXB_LOW); //Action taken on PWM1A and PWM1B, when FAULT0 occurs
    mcpwm_fault_set_oneshot_mode(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_SELECT_F1, MCPWM_FORCE_MCPWMXA_LOW, MCPWM_FORCE_MCPWMXB_HIGH); //Action taken on PWM1A and PWM1B, when FAULT1 occurs
    mcpwm_fault_set_oneshot_mode(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_SELECT_F2, MCPWM_FORCE_MCPWMXA_HIGH, MCPWM_FORCE_MCPWMXB_LOW); //Action taken on PWM0A and PWM0B, when FAULT2 occurs
    mcpwm_fault_set_oneshot_mode(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_SELECT_F1, MCPWM_FORCE_MCPWMXA_LOW, MCPWM_FORCE_MCPWMXB_HIGH); //Action taken on PWM0A and PWM0B, when FAULT1 occurs
#endif
#if MCPWM_EN_SYNC
    //6. Syncronization configuration
    //comment if you don't want to use sync submodule, also u can comment the sync gpio signals
    //here synchronization occurs on PWM1A and PWM1B
    mcpwm_sync_enable(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_SELECT_SYNC0, 200);    //Load counter value with 20% of period counter of mcpwm timer 1 when sync 0 occurs
#endif
    //7. Capture configuration
    //comment if you don't want to use capture submodule, also u can comment the capture gpio signals
    //configure CAP0, CAP1 and CAP2 signal to start capture counter on rising edge
    //we generate a gpio_test_signal of 20ms on GPIO 12 and connect it to one of the capture signal, the disp_captured_function displays the time between rising edge
    //In general practice you can connect Capture  to external signal, measure time between rising edge or falling edge and take action accordingly
    mcpwm_capture_enable(MCPWM_UNIT_0, MCPWM_SELECT_CAP0, MCPWM_POS_EDGE, 0);  //capture signal on rising edge, prescale = 0 i.e. 800,000,000 counts is equal to one second
    mcpwm_capture_enable(MCPWM_UNIT_0, MCPWM_SELECT_CAP2, MCPWM_POS_EDGE, 0);  //capture signal on rising edge, prescale = 0 i.e. 800,000,000 counts is equal to one second
    mcpwm_capture_enable(MCPWM_UNIT_0, MCPWM_SELECT_CAP1, MCPWM_POS_EDGE, 0);  //capture signal on rising edge, prescale = 0 i.e. 800,000,000 counts is equal to one second
    //enable interrupt, so each this a rising edge occurs interrupt is triggered
    MCPWM[MCPWM_UNIT_0]->int_ena.val = CAP0_INT_EN | CAP1_INT_EN | CAP2_INT_EN;  //Enable interrupt on  CAP0, CAP1 and CAP2 signal
    mcpwm_isr_register(MCPWM_UNIT_0, isr_handler, NULL, ESP_INTR_FLAG_IRAM, NULL);  //Set ISR Handler
#endif
    vTaskDelete(NULL);
void app_main(void)
    printf("Testing MCPWM...\n");
    cap_queue = xQueueCreate(1, sizeof(capture)); //comment if you don't want to use capture module
    current_cap_value = (uint32_t *)malloc(CAP_SIG_NUM*sizeof(uint32_t)); //comment if you don't want to use capture module
    previous_cap_value = (uint32_t *)malloc(CAP_SIG_NUM*sizeof(uint32_t));  //comment if you don't want to use capture module
    xTaskCreate(disp_captured_signal, "mcpwm_config", 4096, NULL, 5, NULL);  //comment if you don't want to use capture module
    xTaskCreate(gpio_test_signal, "gpio_test_signal", 4096, NULL, 5, NULL); //comment if you don't want to use capture module
    xTaskCreate(mcpwm_example_config, "mcpwm_example_config", 4096, NULL, 5, NULL);
  • \$\begingroup\$ You could have elaborated more rather than just pasting a bunch of sample code. It's not clear which part do what if you aren't already familiar with the peripheral (like the OP obviously) \$\endgroup\$ Feb 12, 2021 at 17:12
  • \$\begingroup\$ Sorry for that.Short Version: in mcpwm_capture_enable(MCPWM_UNIT_1, MCPWM_SELECT_CAP1, MCPWM_POS_EDGE, 80); 80 musst by 0. This Value is the prescaler for the incoming Pulses. Not for the "free running" Counter. 80 means that only evry 80th incoming Impulse rise a interupt. \$\endgroup\$ Feb 12, 2021 at 22:24
