I am studying boost converters in my power electronics class. Something I cannot wrap my head around is the voltage across the inductor.
When the low side switch (the switch connected to ground, see diagram below) is closed, the circuit is just an inductor in series with a DC voltage source. According to every reference I can find on the internet and an LTspice simulation I downloaded from my professor, the voltage across the inductor is just Vi and stays at Vi for the time that the low side switch is closed. This makes sense according to KVL - the voltage around the loop has to equal 0 one way or another.
However, wouldn't the voltage be changing? If we just take the simple circuit of a DC voltage supply in series with an inductor, eventually after some time, the voltage across the inductor would just equal 0 and the source would be shorted to ground, right? So why is it different in a boost converter? What makes the voltage across the inductor stay constant at Vi?
