A book says that the power diode is 'not controllable' whereas a 'Thyristor' is semi-controlled and a 'MOSFET' is fully controlled. What do these degrees of controllability mean? Is it somehow related to feedback loops?
\$\begingroup\$ Do you know , what is difference between a diode is in forward bias and a thyristor is in forward bias ? \$\endgroup\$– user215805Commented Mar 21, 2021 at 16:07
\$\begingroup\$ Do you know what the verb "control" means? \$\endgroup\$– Criticizing Israel not allowedCommented Mar 21, 2021 at 18:35
\$\begingroup\$ @user215805 I do. When a diode is in forward bias, it automatically conducts electricity. But when a thyristor is in forward bias, we still need to undertake the additional step of providing a pulse of current to the gate. Thank you for the reverse question. I understand what the degrees of controllability mean now, however I do think that these terms are a bit far fetched. Anyway \$\endgroup\$– MurdockCommented May 12, 2021 at 9:48
Figure 1.
- (a) A diode will conduct if it is forward biased. There is no control pin on it. It is not controllable.
Figure 2. The upper waveform shows the result of the diode or the thyristor when triggered at the start of the half-cycle. The third waveform shows the result of triggering half-way through the half-cycle. Image source: Electronics Tutorials.
- (b) A thyristor has a control pin and can be turned on part way through the AC cycle. Once triggered it remains on until the current through it falls to zero. In that regard it is semi-controllable - you can turn it on but will require special circuitry to force it off if you don't want to wait for the next AC zero-cross.
- (c) A MOSFET's conductivity can be controlled by its gate voltage and can be increased or decreased on command. It is fully controllable.
Feedback is used to adjust the actual output to bring it closer to the desired setpoint. It's irrelevant in (a), it might be useful in (b) to control the resultant output voltage or power and it would be most often found in (c) to control the current or voltage in the load.
Controllability is a concept that appears in control systems.
Yes, it is related to negative feedback loops.
