I have a setup with a bunch of synthesizers and guitar pedals wired together with audio cables. I'm also powering the guitar pedals all with the same multi-plug 9V adapter. Since some of the pedals don't have dedicated power switches I bought some inline DC switches online that you stick between the adapter cable and the pedal so you can switch it on and off.
The weird phenomenon I'm experiencing is that switching one pedal on also switches on the others (whose switches are turned off) because the switch only cuts the power line and due to the audio cable connections there's actually an electrical circuit being formed across the ground connection of the audio cables and power line. Basically a pedal is linked to another via the ground wire, that other pedal is linked to a synthesizer via audio cable, another audio cable is linked from the synth to the first pedal, and now we have a ground circuit. It doesn't seem unsafe right now as far as I can tell, just inconvenient.
What I've realized is that if I had switches that cut both power and ground, they would work correctly in my scenario. My question is, would that be safe? I understand cutting the ground wire is supposed to be bad when power is live, but is this a big deal if both are cut and the voltage/amps are relatively low?
