I want to measure grid voltage with AMC1200b. I used a resistor voltage divider and I lowered grid voltage from 110v(rms) to 110mv(rms). I fed the 110mv(rms) signal to AMC1200b (for the first side of AMC1200b I used a 5v power supply and for the second side I used an isolated 3.3v power supply). The problem is, based on the datasheet, the gain should be fixed and 8, but it is 4 and I am losing some resolution for sampling. I also used a filter for the shunt resistor like it was in the datasheet( 2*12ohm resistors + 330pF capacitor).
Could you please let me know what's wrong with the circuit?
