I want to use Sm8s003f3p6 as a frequency counter , My program is as described in stm8s reference manual 17.4.3 External clock source mode 1 and pulse counting is done in pin PC7 using HSI 16 Mhz , but the speed of counting is very low , for example for a 10 mhz pulse in 1 ms TIM1_CNTRL counts to 60 .
I want to know is this speed of counting correct ?
Is it possible to have faster counting ?
what is the maximum counting frequency of stm8s003f3p6?
I want to make a frequency counter and need to have more speed to count high frequency wave . As I said for 10 mhz pulse , counter is 60 so each increment of counter is equal to 10Mhz/60 = 167 khz that is not a good resolution . .
my code for timer counter is as follows
#include <iostm8S003f3.h>
#include <intrinsics.h>
unsigned long int fr=0,f=0; // fr increment in timer1 overflow , f is number of final pulse counting
unsigned char h; //dummy variable
int main(void)
__disable_interrupt();
InitialiseSystemClock();
InitialisePorts();
config_counter();
TIM1_IER_UIE = 1; // enable timer 1 interrupt
__enable_interrupt();
while (1)
fr=0;
TIM1_CNTRH = 0; //reset counter
TIM1_CNTRL = 0;
TIM1_CR1_CEN=1; // start counter
delayms(1);
TIM1_CR1_CEN=0; // stop counting
// calculate counter as a number = TIM1_CNTRH*256 + TIM1_CNTRL + fr*65536
// fr will increment whenever tim1 counter overflows
h=TIM1_CNTRH ;
f=h*256;
h=TIM1_CNTRL;
f=f+h;
f=fr*65536+f;
void delayms(int t)
int d;
while(t--)
for (d = 0; d < 2020; ++d) ; //approximately 1 ms delay with 16 mhz clock
#pragma vector = TIM1_OVR_UIF_vector
__interrupt void TIM1_UPD_OVF_IRQHandler(void)
fr++;
TIM1_SR1_UIF = 0;
void InitialisePorts()
PC_DDR_DDR7=0; // pc7 as input
PC_CR1_C17 = 0; // no pullup
PC_CR2_C27 = 0; // no interrupt
void InitialiseSystemClock()
CLK_ICKR = 0; // Reset the Internal Clock Register.
CLK_ICKR_HSIEN = 1; // Enable the HSI.
CLK_ECKR = 0; // Disable the external clock.
while (CLK_ICKR_HSIRDY == 0); // Wait for the HSI to be ready for use.
CLK_CKDIVR = 0; // Ensure the clocks are running at full speed.
CLK_PCKENR1 = 0xff; // Enable all peripheral clocks.
CLK_PCKENR2 = 0xff;
CLK_CCOR = 0; // Turn off CCO.
CLK_HSITRIMR = 0; // Turn off any HSIU trimming.
CLK_SWIMCCR = 0; // Set SWIM to run at clock / 2.
CLK_SWR = 0xe1; // Use HSI as the clock source.
CLK_SWCR = 0; // Reset the clock switch control register.
CLK_SWCR_SWEN = 1; // Enable switching.
while (CLK_SWCR_SWBSY != 0); // Pause while the clock switch is busy.
void config_counter()
TIM1_CNTRH = 0;
TIM1_CNTRL = 0; //Reset counter
TIM1_IER = 0; //Interrupt disabled
TIM1_SR1 = 0; //Clear Interrupt
TIM1_CCMR2 |= 1<<0; //External pulse source T1C2
TIM1_CCER1 &= ~(1<<5); //Rising edge
TIM1_SMCR |= (7<<0); //External Clock Source
TIM1_SMCR |= (6<<4); //T1C2 Input Source
TIM1_CR1 &= ~(1<<0); //Counter disabled
return;
button. Make sure that the indenting is correct and remove unnecessary blank lines. Use proper capitalisation for part numbers and SI units such as 'Hz'. Preview the question before posting it. Welcome to EE.SE. \$\endgroup\$
