This question is of a purely theorethical nature.
Applying pressure to a piezoelectric material creates voltage, and the inverse is also true. I have seen this likened to a spring, and was wondering how far you could take this concept.
Imagine the following scenario: You apply a voltage to cause a mechanical oscillation, then you use glass or plastic to encase and freeze it in an excited state. (I know it's impossible, the crystal itself would melt and the material would take some time to settle, but bear with me.)
Frozen in that state, question 1, would it retain its potential mechanical energy, and 2, if you were to break the glass would it still produce a voltage?
