In order to characterise an energy harvester, I want to measure its power output. It is a rotary harvester (basically like a regular generator) with three phases.
I do not have fancy measuring equipment, just an oscilloscope and a handheld multimeter, neither with interfaces to a PC.
My idea would be to rectify the voltage with a B6U bridge and put a load resistor behind it, then measure the voltage across R_load over time. The oscilloscope can log the measured voltage every 2 µs in a csv and I would calculate the integral below numerically for each point measured.
Is this a suitable way to do so, or do you have another suggestion?
I could also charge a capacitor for a certain amount of time and measure its voltage and then maybe calculate the stored energy.
