I've read many question on here about how to connect multiple BMS controlled batteries in parallel to step up amps. Is this necessary to step up amps as opposed to running all the cells in series and stepping down the voltage instead?
For instance 4 X 18650 3.7v cells connected with a target voltage of 7.4v and the highest amps possible.
- Considering cost and safety
- Would you get similar amps from a single BMS that connects all 4 cells in series and is then run through a buck converter to get 7.4v?
- Or running 2 x 2 cell BMS producing 7.4v each, then run in parallel and charged in parallel?
It just seems like a lot of cost, frustration, and safety issues can be resolved by using a single BMS and a buck converter to achieve this goal, provided they produce similar amps.
