I have two devices A acting as (UFP) and B (UFP or DFP). Device A supplies 3.3V to device B on SBU1 and SUB2 pins of USB C 3.1.
I am not using Vbus to supply power to Device B. SuperSpeed pins of USB C 3.1 are not used as superspeed signals but they are just used for transferring signals from B to A.
My question is can I achieve transmission of signals by using Device A as UFP and Device B also as UFP? Basically can I pull down the CC pins of device A and B?
Note: I am using HD3SS460 MUX on Device A.
Yes, I think it is possible. If you connect the CC lines of the products to some relays, you can choose to connect them to high/low depending on the configuration.
