I found these things (they're aerials I presume) with six "spokes" at the Perth Airport. Does anyone know what they're for? Thanks.
Source: https://www.youtube.com/watch?v=WjJYSquq4jU&ab_channel=RowinDreef
Any array of aerials can be used, with sufficient extra hardware and processing, for doing any phased array or beamforming application.
However, certain arrays lend themselves to very low cost implementation. That radial pattern is consistent with a phase modulated direction finding receive antenna array (which is not saying that's what it is).
In use, such an array would switch reception from one to the next aerial at typically audio frequencies, making a whole circuit round the circle in a millisecond or so. This would impose phase modulation on the carrier of the received signal. The phase of the phase modulation (are you still with me?) with respect to the switching pattern would directly give the direction of arrival of the signal.
The hardware needed is minimal. A controllable antenna switch, to switch the inputs into a single, standard, audio receiver. A phase sensitive detector, which could be analogue, or a program running on a PC with an audio input, to resolve the direction.
The system is entirely passive, and needs no particular signal or cooperation from the sender.
Going by the dimensions obtained from Google maps, they appear to be two 7-element ESPAR antennas for HF, located 170 m apart.
ESPAR - Electronically Steerable Parasitic Array Radiator.
