I am doing a hydroponics project at school. For this I need to make a circuit for a Ph sensor, I was going crazy looking and I found only one that did not really work for me, I will add photos. The voltages do not give me as they should give me Where I got the schematic from is here: Building a pH meter circuit - is it feasible? Abe Karplus did answer.
By the way, I didn't use the op amp that this man used. I used a UA741CP.
Then I used the same scheme that that man came up with to use in proteus and then make the board.
