-2
Which pins have to be shorted for this to start?
Thanks in advance.
    \$\begingroup\$ i took the liberty to fix your question ... does anybody know ...? is not a question about the power supply \$\endgroup\$
    – jsotola
    Commented Nov 4, 2021 at 0:44
From the datasheet: VO1 and VO2 ENA have to be pulled to ground to enable the respective outputs.
  • \$\begingroup\$ Fantastic! I didn't search the datasheet, thank you very much \$\endgroup\$
    – Gustavo
    Commented Nov 4, 2021 at 1:03
  • \$\begingroup\$ I only need the 12v where do you think Vo2 ENA should go? psup, vaux RNT, vo2-s, Vo2CS? \$\endgroup\$
    – Gustavo
    Commented Nov 4, 2021 at 2:08
  • \$\begingroup\$ I would try VO2 RTN. \$\endgroup\$
    – vir
    Commented Nov 4, 2021 at 16:16
  • \$\begingroup\$ Vaux RTN works great \$\endgroup\$
    – Gustavo
    Commented Nov 5, 2021 at 4:22
  • \$\begingroup\$ thanks again vir \$\endgroup\$
    – Gustavo
    Commented Nov 5, 2021 at 4:23
