I’m trying to choose/work out if I need capacitors for the input and output of two DC/DC converters.
The first converter is a Murata PAE-29/3-D48, powering this along a ~30cm cable, and a bike headlight, using ~100ma with a ~40cm cable.
The second is a Mornsun VCB4805SBO-30WR3 (5v version), powering a wireless phone charger which uses ~1.3A with a ~60cm cable.
Both will be powered by a 48v lithium battery pack, on a bike which will be used in weather from -5 to 25 C.
My main point of confusion is the capacitor ripple current rating - I’m aware I should aim for it not to be exceeded, but both DC/DC datasheets only list ripple voltage and I don’t know how to calculate the current (or the frequency for that matter). The datasheets also mention choosing a low ESR capacitor, but I don’t know what counts as ‘low’, or why many capacitors don’t seem to list an ESR rating at all.
Finally, neither datasheet seems to mandate the use of input or output capacitors, and I’m not sure how to know whether they’re needed.
Thanks!
