The Friis path-loss equation using isotropic antennas can be expressed in decibels: -
Path-loss (dB) = 32.45 + 20\$log_{10}\$(f) + 20\$log_{10}\$(d)
Where \$f\$ is in MHz, \$d\$ is in kilometres and free-space is assumed.
At 2.4 GHz and 2 km, that's a path-loss of 32.45 dB + 67.60 dB + 6.02 dB = 106 dB.
Your transmit power is 1 watt (+30 dBm) and your receiver sensitivity might be -85 dBm so, that is a difference of 115 dB hence, you have a surplus of 9 dB and, you can use isotropic antennas in free space for this. Hence your value for antenna gain is negative.
However, over terrain (obstacles) and, with weather changes and man-made noise, a general approximate rule of thumb is to add 20 or 30 dB to your path loss to cater for these extremes.
This is called fade-margin.
Now, your path-loss is 136 dB (30 dB added) and, your transmit power and receiver sensitivity fall-short by 21 dB hence, you need antenna-gain in my humble opinion.
Another Q and A on a similar subject.
