If I have an antenna and I wish to measure its impedance. I have two impedance values, Z=125.52-j207.36Ohms and Z=8.14-j39.6Ohms, and I do not know which one is correct/ which one applies to this antenna.
We know its impedance has a resistive and reactive component. We know its impedance will change with frequency due to the reactance changing with frequency.
Would it be possible to measure the resistance of the antenna using a standard multimeter and if the resistance measured is close to the resistive component in one of my impedance values, then that impedance value must be the correct one?
