I used this wiring schematic for a couple of my ESP8266-12F projects for programming mode:
As I built enough confidence with the module, I decided to go ahead with a PCB design. When I try to upload a sketch, it wouldn't go into programming mode although I think my design is correct. I checked the connections between pads and headers and they all connected. Am I missing something here? Would you please check the connections and let me know of possible cause?
esptool.py v3.0
Serial port COM4'
Connecting........_____....._____....._____....._____....._____....._____...._____
esptool.FatalError: Failed to connect to ESP8266: Invalid head of packet (0xE0)
  • \$\begingroup\$ I had a similar problem recently. It was due to not enough capacitance on the power supply. Fatten up your gnd and vcc tracks and add a 22uF 25V ceramic capacitor close to the module pads. Note that it is not a good idea to run tracks under the antenna or even the pcb. \$\endgroup\$
    – Kartman
    Commented May 14, 2022 at 19:12
Your top image shows TX to TX and RX to RX. Is that really correct or should it be TX to RX?
  • \$\begingroup\$ I used the upper wiring tens of times. However, I swapped TX & RX but got the same issue. \$\endgroup\$ Commented May 14, 2022 at 11:04
  • \$\begingroup\$ this answer should really be a comment \$\endgroup\$
    – jsotola
    Commented May 14, 2022 at 18:34
  • \$\begingroup\$ Your enable pin is pulled low on one and high on the other. And, are you enabling GPIO-0 to the proper high/low to enable programming of the ESP12F? \$\endgroup\$ Commented May 14, 2022 at 21:17
