I'm trying to learn more about how to engage a capacitive touchscreen without using a human finger. Full disclaimer I'm in mechanical engineering (notoriously known to have difficulty comprehending concepts not physically observable), so I'll try and understand as best I can to your responses. I've done some of my own research and came across this thread which asked a similar question: How to use a capacitive touch screen without a human hand
My question is, however, is it possible to stimulate the touchscreen with a electrically conductive plate that is connected to a battery via a wire? If I understand correctly from the attached link, I would need a way to connect the touchscreen to a much larger body such as our own bodies, but would this be just as, if not more effective when connected to the negative terminal of a battery (theoretically speaking)?
And just to clarify, there would be no need to provide any current from the battery to make this work correct?
Thanks in advance guys!
