I am writing a SCPI script in Python for the Siglent SDS1104X-E. I have been banging my head for a few days trying to get this to work. Below is my main py file:
    #     Set the Scope IP address and Port number
    SCOPE_IP_ADDR = "192.168.1.220"
    SCOPE_IP_PORT = 5025
    #     Useful Variables
    channel_list = [1, 2, 3, 4] # The values in this list correspond to the 4 channels on the scope.
    channel_1_dict = {'enable': 'True', 'bandwidth': 'ON', 'coupling': 'D1M',
                      'volt_div': 1, 'volt_offset': 0, 'probe_attenuation': 1}
    sc.config_chan(channel_list[0], channel_1_dict['enable'], channel_1_dict['volt_div'],
               channel_1_dict['volt_offset'], channel_1_dict['coupling'],
               channel_1_dict['bandwidth'], channel_1_dict['probe_attenuation'])
    sc = sds.SDS1104X_Object(SCOPE_IP_ADDR, SCOPE_IP_PORT)
    sc.open_connection()
    sc.reset_inst()
    print(sc.get_id())
My problem is that the reset command (*RST) does not happen fast enough. When configuring multiple channels, it does not always set all of the channels.
Below is a snip from the object that sends the actual commands
    def reset_inst(self):
        self._send_cmd("*RST")
    # helper functions
    def _send_cmd(self, cmd):
        """ send cmd if connected, no resp """
        if self.connection.is_connected:
            self.connection.write(cmd)
    def _send_qry(self, cmd):
        """ send cmd if connected, return resp """
            return self.connection.read_raw()
        else:
            return None
The only way I can get this to work is to use the Python "sleep" command after every SCPI command
    time.sleep(3)
The programming manual says to send the *OPC query in order to wait for a command to finish:
I guess I could just put these hard delays everywhere in my script but it seems really clunky and not the best way.
*RST causes the entire scope to reset. It doesn't send a response before the reset, and it can't send one afterwards - the reset causes it to "forget" everything that happened before the reset.
The programming guide tells you when a command will send a response. A command with a response will have a block named "RESPONSE FORMAT" in its description.
What you want to do is to send the "*RST" then periodically ask if the scope is ready to talk to you.
The examples in the guide start with asking for the device identification using the "*IDN?" command.
Send your "*RST" then a short pause (hundred milliseconds or so) then send the "*IDN?" command. Repeat the pause and the "*IDN?" command until you get a good response.
When you look at other commands, take note of whether or not they send a response. If they don't, then you will have to find a different way to see if they succeeded.
For example, the "*RCL" (recall) command doesn't provide a response. If you want to load a particular bunch of settings you have to send the "*RCL" then check the status of the "EXecution error status Register" (command "EXR?") to see if it worked properly.
  • \$\begingroup\$ I edited my question because I see that I had actually pasted in my code incorrect. I am actually sending IDN? after the RST. I do the RST as an initial clearing of everything when the script first runs. Excuse my ignorant question, but how do I check the execution status register. There doesn't seem to be a command for that. \$\endgroup\$
    – Frank
    Jun 30, 2022 at 14:07
  • \$\begingroup\$ Oh, I see, we are looking at different manuals this is what I am looking at manual. I will go over the commands in your manual and I will let you know what I figure out. \$\endgroup\$
    – Frank
    Jun 30, 2022 at 14:15
  • \$\begingroup\$ Apologies for overloading your comment, just a quick update. I am actually using the allstatus command ALST?, and that seems to be a workaround. My channels and trig get set. The problem is that there are multiple manuals floating around online. So now on to the next problem. hahaha. \$\endgroup\$
    – Frank
    Jun 30, 2022 at 14:59
  • \$\begingroup\$ Yeah, ALTS? gets you all the registers. \$\endgroup\$
    – JRE
    Jun 30, 2022 at 15:00
