I'm currently planning a PLC project but I'm not sure how to put the components together.
About my setup: I want to integrate a Siemens S7-1200 as master PLC.
The PLC should control a subordinate control via Modbus/TCP (= Modbus Client).
In addition, an OPC UA server should also run on the PLC, which sends sensor data to an edge gateway.
The PLC should also have 4 digital inputs and outputs.
I am now stumped on choosing the right S7 central processing unit. Is the PLC 1215C sufficient for this purpose?
The PLC has two PROFINET ports.
Quick search in Siemens industry mall show OPC/UA is an optional add-on, so yes, 1215C can be configured to use it.
SIMATIC OPC UA S7-1200 Basic 6ES7823-0BA00-2BA0
