11
I'm interested in developing a very high frame rate OLED display capable of displaying ~1000fps with a resolution of around 1200x800 or so. This obviously has some pretty severe bandwidth requirements, and will likely require the use of an FPGA to implement a custom controller as typical display controllers don't run faster than 60-120Hz. At the risk of really showing my ignorance, with a "raw" OLED display (no controller) should I be able to drive the display at these rates? I'm sure whatever display controller comes with the display will be unhelpful, so I'd be starting from example controller code for the FPGA.
  • \$\begingroup\$ I think that after the first edit, the question is more suitable (as it is more questioning the theoretical limits of a "raw" OLED display rather than asking who can implement a fitting display. \$\endgroup\$
    – Shamtam
    Commented Apr 2, 2013 at 4:27
  • \$\begingroup\$ May I ask why you need a 1000fps screen? You wouldn't be able to see the change anyway. I can understand a 1000fps camera but a screen... \$\endgroup\$
    – clabacchio
    Commented Apr 2, 2013 at 9:30
  • \$\begingroup\$ @clabacchio: If a scanned screen is moving relative to the viewer's eyes, frame rate can greatly affect its appearance. Many 60Hz dot scanned matrix displays will appear to "break up" if their position relative to the viewer's eyes doesn't follow a smooth path. \$\endgroup\$
    – supercat
    Commented Apr 2, 2013 at 16:03
    \$\begingroup\$ @ScottSeidman: One scenario I can think of would be if one were trying to produce a 3D appearance by having a display which was moved rapidly toward or away from the viewer. Under such a scenario, if one wanted a visual refersh rate of 50Hz and were using a triangle wave to move the display, and if one could reverse the scan direction on the display, a 1000Hz refresh rate would give the appearance of at most 20 stacked planes. \$\endgroup\$
    – supercat
    Commented Apr 3, 2013 at 15:54
    \$\begingroup\$ @ScottSeidman: To be sure, shaking an OLED panel at 50Hz might not be good for longevity, but shaking a mirror via which it was viewed shouldn't pose a problem. Upon some further consideration, one wouldn't even necessarily have to "shake" a mirror if one had a number of spiral-shaped mirrors on a spinning mechanism. \$\endgroup\$
    – supercat
    Commented Apr 3, 2013 at 15:56
A suggested approach to updating a 1200 x 800 pixel display at 1000 fps, would be to break up the display into a matrix of lower resolution OLED panels, ideally OLEDs with so-called "edge-to-edge active display". For instance, a 2 x 2 matrix of 640 x 480 OLED panels would provide a bit more than the specified resolution. However, these sub- panels selected must themselves allow refresh rates of 1000 frames per second, as well.
Each panel needs to be controlled through a separate signal channel. Depending on the capability versus price of the FPGA chosen, a single FPGA may be used to drive one or more of the panels.
This is similar to the way ultra-large displays are created for stage performance backdrops, for instance, using a matrix of standard large screen HD LCD or LED televisions. Each TV is typically driven off a separate video source. Allowance is made for bezel distances, cropping off an appropriate amount of the image at each edge of each TV.
As the application itself is not described in the question, an assumption is that a somewhat contiguous display is required. Unfortunately, using separate panels will not provide contiguous display area, as the connections to each OLED panel in the matrix have to come out somewhere. Thus, bezel-like gaps will need to exist between panels, similar to the matrix-of-TVs approach mentioned.
If this is unacceptable, the alternative is to select an OLED panel of the desired resolution, that brings out individual signal rows and columns to a connector and allows these to be driven in definable banks. Typical OLED panels with Chip-on-Glass (COG) controllers will not work this way, raw OLED panels will need to be sourced.
Individual banks of OLED rows / columns would then be controlled via separate channels and conceivably separate controllers, to achieve the desired end-result display.
  • \$\begingroup\$ Excellent comments. As your profile indicates you are a gamer, are you familiar with Blur Busters? (I'm the owner of Blur Busters, a "Better Than 60Hz" website.) \$\endgroup\$ Commented Nov 25, 2017 at 18:25
  • \$\begingroup\$ Also, OLEDs also come in microdisplay formats (e.g. viewfinder of a Sony A6000 camera), one could theoretically run 16 displays at 60Hz, separating 1 out of 16 refresh cycles for each display. Use a rapid-rotating mirror+shutter, to generate a 960Hz display out of 16 different 60Hz displays. Viola -- 960Hz display, albiet one that needs projection/magnification (viewfinder/VR headset) to be seen. \$\endgroup\$ Commented Nov 25, 2017 at 18:28
EDIT 2018:
There is a new definitive article about the confirmed visual benefits of 1000 Hz: Blur Busters Law And The Amazing Journey To Future 1000Hz Displays.
Older Post Follows:
Actually, 1000fps@1000Hz would have some human eye benefit under certain conditions:
  • Michael Abrash of Valve Software: Down the VR rabbit hole: Fixing judder
    http://blogs.valvesoftware.com/abrash/down-the-vr-rabbit-hole-fixing-judder/
  • Why We Need 1000fps @ 1000Hz this century
    http://www.avsforum.com/t/1484182/why-we-need-1000fps-1000hz-this-century-valve-software-michael-abrash-comments
  • John Carmack of id Software: QuakeCon keynote talking about motion blur http://www.youtube.com/watch?v=93GwwNLEBFg&t=5m35s
Finite-framerate displays have the problem of having either sample-and-hold or stroboscopic/wagonwheel effects (or both). Eye-tracking based motion blur results from sample-and-hold, hold-time, persistence. Lots of scientific papers cover this already (Search science paper sites for "sample-and-hold" or "hold-type" displays).
Mathematically, 1ms of persistence equals 1 pixel of motion blur during 1000 pixels/sec motion. A 1000fps@1000Hz flicker-free display would simultaneously eliminate a lot of stroboscopic effects (wagonwheel artifacts) AND simultaneously eliminate motion blur, without using flicker. This is great for Holodeck situations (e.g. VR goggles). And you wouldn't need to add artificially-generated motion blur. You'd just finally let the human brain add its own natural motion blur, with no motion blur artificially forced upon you by the graphics or by the display. So, 1000fps@1000Hz would be far closer to reality, while eliminating the stroboscopic/wagonwheel artifact problem.
Sample-and-hold motion blur can be viewed in this animation:
www.testufo.com/#test=eyetracking
This animation is an excellent demo of "pick-your-poison" problem of finite-refresh displays. The problem is very clearly visible to the human eye even when viewing on a 120Hz gaming LCD or a 200Hz scientific CRT.
  • Animation has motion blur when viewing on LCD's
  • Animation has stroboscopic effect when viewing on CRT's
To simultaneously fix both at the same time (important for VR / Holodeck situations), you need to make the refresh rate resemble something infinite. That is not possible. However, a 1000fps@1000Hz display would sufficiently reduce/eliminate both stroboscopic effect / motion blur. Even the Oculus people said this; and the big names in game industry (Michael Abrash of Valve Software, John Carmack of id software) has already confirmed the benefits of ultrashort persistence flicker-free displays like this.
Did you know AMOLED generally has more motion blur than a 120Hz+ gaming LCD?
A high-refresh-rate OLED is extremely challenging, but not impossible. Several OLED's have actually reported to have a motion blur issue -- The big problem is the switching speed of transistors in an AMOLED. You only have a very ultra-brief time (typically under a microsecond) to trigger a transistor in an AMOLED screen, so the transitor switching speed is really slow.
If you plan to subdivide an OLED into multiple segments to refresh different parts of an OLED simultaneously, subdivide your OLED into vertical strips, and scan each segment in sync with each other. Otherwise, you get potential multiscan artifacts that can show up as stationary tearlines (this was common problem in old dual-scan LCD's of the 1990's; they showed a stationary tearline in the middle of the screen during horizontal motion).
Motion tests such as TestUFO will be a big benefit to your testing.
One way to do 1000fps on OLED is to use a PMOLED screen, but you will lose a lot of brightness (you need OLED pixels thousands of times brighter to compensate for the long dark periods between flickers). You will, however get excellent motion resolution.
But if you don't mind a bit of flicker (e.g. non-objectionable 120Hz flicker) what about using strobing to gain equivalent motion resolution of a higher framerate? Strobing is the same principle as black frame insertion. Some displays do this to reduce motion blur (e.g. Sony's Motionflow Impulse, nVidia's LightBoost, etc), much like the principle of CRT or plasma flicker. Doing a 1/1000sec flash at lower refresh rates (e.g. 120Hz) would have the same amount of motion blur as a 1000fps@1000Hz sample-and-hold display. Recently, strobe backlights have been developed. I've done some electronics hacking. See Electronics Hacking: Creating a Strobe Backlight for engineering on massive reductions of motion blur on LCD displays.
The pursuit to a 1000fps @ 1000Hz display is definitely worthwhile.
Ignore the naysayers who say the human eye can't tell.
  • \$\begingroup\$ There is also a really very good advanced/scientific forum discussion thread about the theoretical usefulness of 1000fps at 1000Hz: forums.blurbusters.com/viewtopic.php?f=7&t=333 \$\endgroup\$ Commented Mar 4, 2014 at 17:16
    \$\begingroup\$ UPDATE: Since I posted this message, Oculus has released Development Kit 2 VR goggles (aka DK2) with a rolling-scan OLED with only ~2ms persistence. The low-persistence via a rolling scan, is a form of black frame insertion, and presents a more realistic technological option than ultrahigh framerate. 2ms persistence is achievable via black frame insertion (each frame visible for 2ms, with remaining time between frames black) or by using full persistence of 2ms which requires 500fps@500Hz (each unique frame visible for 2ms), both equivalent amount of motion blur in eye-tracked situations. \$\endgroup\$ Commented Jul 14, 2014 at 19:10
I'd like to follow up with two new "Ultra High Hz" developments. I now have a peer-reviewed conference paper and presentation on a new display motion blur testing technique.
(1) I have received a prototype 480 Hz LCD display and, the difference is indeed visible to human eye. Here are my test results of 480 Hz (via Blur Busters).
(2) I may have figured out a way to potentially achieve higher refresh rates on an OLED. It is very OLED panel wiring dependent, but the thread is here in the Display Science, Research & Engineering Forum
Some example images include a 2-channel rolling scan OLED that has an "ON" scan pass and "OFF" scan pass -- to intentionally pulse the OLED (like a CRT) to reduce motion blur. This is what Sony Trimasters and Dell U3017Q does.
OLED rolling scan
This could in theory be used with concurrent scan windows for artifact-free ultra high-refresh-rates -- depending on how many channels the OLED has.
  • \$\begingroup\$ It seems that you accidentally created two accounts Mark -- you can have them merged so that all your reputation gets put together into one pool \$\endgroup\$ Commented Aug 18, 2017 at 11:48
  • \$\begingroup\$ Also, some new content. GPUs will have lots of difficulty doing 1000fps at 1000Hz. However, Oculus came up with a very clever trick called reprojection/timewarping to convert 45fps into 90fps for VR through a lagless interpolation technique. Over time, geometry/parallax-aware 3D interpolation in silicon, will it possible to nearly flawlessly upconvert 100fps into 1000fps with much less silicon than rendering 1000fps natively. I call this "Frame Rate Amplification Technologies" (FRAT), discussed in this Blur Busters Forum thread \$\endgroup\$ Commented Nov 25, 2017 at 18:18
  • \$\begingroup\$ Yet another update: I've written a new article about the advent of 1000 Hz gaming displays: Blur Busters Law: The Amazing Journey To Future 1000Hz+ Displays. This article is MUCH more comprehensive about explaining the necessity of ~1000Hz as a method of "blurless sample-and-hold". Ultra-high frame rates are required for flickerless low persistence. Basically, blurless without the requirement of strobing or black-frame insertion. \$\endgroup\$ Commented Dec 26, 2017 at 20:55
