Please excuse the naivity of this question, I am not an electrical engineer. I need a quick solution, and don't have time to ask our electrical engineer to help. A supplier will bring a device they want to show me, and I would like to see it in action. They will not have a cable to connect it (yes, strange). So they told me, if I can improvise a required cable, I can see the device working.
It is about an optical fibre switch: light comes in via an input fiber and leaves via one of the few output fibres. The switch is powered has one D-sub 25 connector. Power requirements are 5 V, 150 mA. The output is selected by providing a TTL signal on 4 pins in the connector. I want to use only the 1st and the 2nd outputs, for which the codes are 0 and 1. Here is the instruction they sent me:
So I wonder, will the following trivial circuit do what I want?
I hope that in switch position 1, it outputs a TTL code 0000, and in switch position 2, it outputs 0001, according to the table above. I also hope that by connecting things like this I have zero chance of burning the device. As the power supply, I am planning to use a simple prototype board power supply circuit powered via USB (from a phone charger).
