My dad has a 100 year old sailing yacht that he's spent the last 37 years restoring and is almost finished. One of the last few things is the navigation lamps; these would normally use kerosene, but we're keen to convert them to LED. We also don't want unsightly wiring, or to have to pierce the deck for cabling, so think a LiPo battery should work.
I'm a (the horror!) Mechanical Engineering grad so electronics really aren't my strength, so I thought I'd better check:
The 12v bulbs we need to use (to give us the required visibility range) are 50 LED ones with a 3.5 watt draw. I think I can use a 4s 3300mAh 14.8v LiPo battery pack (this will fit within the size constraints of the nav lamp), giving approx 11 hours of duration:
3.3mAh x 12v = 39.6Wh / 3.5W = 11.31 hrs.
But this assumes I can use a Buck converter to reduce the voltage from 14.8 to 12v. As I said I'm no expert, but from what I can see it looks like there's a minimum power output required from a buck that the bulb doesn't meet. Is this correct, or can I actually use a Buck? (If it's as easy as that, then it would all fit happily in the nav lamp). Whatever the solution is, it needs to be reliable (simple?), work with the chosen bulb and give at least 10 hours continuous duration.
I'd value your thoughts.
