It would seem that you are asking about this:
Product A is some radio electronics including an antenna.
Product B is some other radio electronics including an antenna.
If so, it is irrelevant if the same antenna happens to be used in both products, they are still two different products and both need to be certified.
You could however design the products so that the RF parts are separated from the rest, and then you may be able to reason about the RF part being compliant since you haven't changed anything affecting it. This is a bit questionable still though, since things outside the RF electronics themselves may affect the radio characteristics, such as the RF supply and product encapsulation. For example changing some switching regulator and still claiming to be compliant would be highly questionable.
As for "pre-certified products" they will list a number of valid antenna reference designs and can be considered certified as long as the recommended antennas are used and you don't do anything which will have impact on radio or EMC characteristics. For example you can't go changing the TX power amp to some custom one in one product and still call it compliant.
