I'm new to electronics and found a very interesting problem and am very eager to solve it.
You need to calculate the total resistance of an infinite circuit attached below. The resistance of each resistor is 1000 Ω.
Redraw the first part of the schematic:
What do you imagine as being the voltage difference between A and B? What about the current through \$R_6\$? And given your answers, what do you imagine adding more resistors across points A and B would achieve, exactly?
You might choose to split the circuit into contiguous blocks if you didn't know the trick to this answer: -
And you might choose to think that the output of the left circuit block connected to another block with the same input impedance. Only then might you notice this: -
