I sheared off a plug from a 3.5 mm headphone jack inside my Roland HP603 piano. After failing to remove the plug, I tried removing the 3.5 mm jack socket from the PCB.
However, the piano still thinks that headphones are plugged in. I think that I need to connect certain pins on the board to fool the piano into realizing the headphones aren't plugged in, but I can't find any circuit diagrams. The jack I removed has 9 pins (not sure why so many, maybe related to 3D sound).
