This question is the closest thing that I found similar to my needs, but it is still quite far from the answer I need.
I have 2 cordless power drills, a 12V green Bosch and an 18V DeWalt. Their battery packs (accumulators) pretty much died by being not used. I want to transform the cordless drills into corded drills, but in a "smarter" way. I saw hacks on the net, but they look too "dirty" (mostly, they have a thin cable between the power supply and the tool).
My definition of smart:
- remove the actual cells from the battery pack;
- replace the cells with a proper power supply;
- connect the end of the power supply to the connector of the battery pack;
- connect the input of the power supply to the wall socket with a cable (through a newly made hole in the plastic wall).
I am not afraid to undergo the transformation except that I do not know how to choose the power supply. The input information that I have is what I can read on the labels: volts and amps on the charger, volts and mAh on the battery pack.
How do I correctly transform these into usable parameters for choosing the power supply (volts, amps, peak amps)?
Of course, I want the power supply to:
- fit inside the battery pack;
- be as efficient as possible;
- optionally / ideally, the power supply should weigh approximately as much as the cells (for comfort while using the tool);
- deliver enough power to the tool.
