I need a current detector that outputs a logic signal (1 or 0). I DON'T need to measure current.
- Detected current: AC.
- Voltage: 220V.
- Load power: ~1kW.
FOR EXAMPLE: I need a current detector that will give out + 5V at a current greater than 0.15A, if the current is less than 0.15A, then the output is 0V (adjust the threshold with a trimmer resistor).
I think that an optocoupler and some kind of transformer current sensor (for example ZMCT103) could be used for this. It is advisable not to use additional power from the LED side (which is located in the optocoupler).
Do you have any thoughts and solutions?
