Screenshots:
I need to apply up to 4.2 V to a 1.1-1.7 Ω coil. I want to apply this voltage only when COIL_ACTV is HIGH. COIL_ACTV is the output of a GPIO pin (3.3 V). To control this, I am using an AO3400A MOSFET.
I have a battery charging IC (TP4056) connecting to my BAT+ as well. Should I disable battery charging when COIL_ACTV is HIGH? I’m worried that the output of the battery charger and the battery will combine and destroy the coil.
Am I running the risks of destroying any of my components? The coil will only be activated for seconds at a time. This device is being built into a vape.
