Currently I have a gasoline generator (2 kW 230 Vac single phase), which has an electric starter. I'm searching for a potential replacement, but the brands I like doesn't have one around that power level with an electric starter.
One idea I have is to excite the stator (via the 230 Vac output pair), as well as the rotor (single pole and winding). And that would be to excite the stator with some DC voltage and then the rotor with the required DC voltage to start the engine. Is the winding shape of both stator and rotor a limiting factor on this? Should something else being considered? I'm also not sure about how to control the direction of movement.
Before spend money on a new generator (before it's needed) and start to trip circuit breakers off, I want to make sure that there is a chance that this will work.
EDIT, for clarification:
- I have a 230 Vac inverter, single phase, 50 Hz (Europe), which can provide more power than the required to make the rotor to spin continuously;
- A 650 W electric drill is able to spin the rotor slightly faster than the starter but still slower than 3000 rpm;
- I have a few alternatives (replace pull cord by electric motor, replace gasoline engine, build the genset from parts, ...) as a backup but I want to pursue the idea of this question, if feasible/cost effective.
