I am getting results I don't understand in a small application (I am still a learner) using PIC16F627A MCU. Schematic of the circuit:
The C source code I have is as follows:
// CONFIG
#pragma config FOSC = INTOSCIO  // Oscillator Selection bits (INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT enabled)
#pragma config MCLRE = ON       // RA5/MCLR/VPP Pin Function Select bit (RA5/MCLR/VPP pin function is MCLR)
#pragma config BOREN = OFF      // Brown-out Detect Enable bit (BOD disabled)
#pragma config LVP = OFF        // Low-Voltage Programming Enable bit (RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EE Memory Code Protection bit (Data memory code protection off)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
#include <xc.h>
#define GPIO_OUTPUT 0
#define GPIO_INPUT 1
#define _XTAL_FREQ 4000000
#define RED_LED PORTAbits.RA1
#define YELLOW_LED PORTBbits.RB3
#define TIMER_RESET_VALUE 206;
long time_count;
long time_threshold = 10;  // 10 x 0.1ms = 1ms = 1kHz
long time_count_max_value = 20000;  // some sort of cutoff
void reset_timer() {
    TMR0 = TIMER_RESET_VALUE;
void __interrupt() isr(void) {
    //reset the interrupt flag
    INTCONbits.T0IF = 0;  // Clear the TMR0 interrupt flag
    RED_LED = ~RED_LED;   // flip the RED_LED bit
    reset_timer();
    time_count++;
    if (time_count >= time_count_max_value) {
        time_count = 0;
void timer_initialise() {
    OPTION_REGbits.PSA = 0;     //Prescaler assigned to Timer 0
    OPTION_REGbits.PS = 0b000;  //Set the prescaler to 1:2
    OPTION_REGbits.T0CS = 0;    //Use the instruction clock (Fcy/4) as the timer
                                //clock.
    INTCONbits.T0IF = 0;        //Clear the Timer 0 interrupt flag
    reset_timer();              //Load initial value into the timer
    INTCONbits.T0IE = 1;        //Enable the Timer 0 interrupt
    INTCONbits.GIE = 1;         //Set the Global Interrupt Enable
void main(void) {
    // TRISA = 0xFF; // default all GPIO as inputs
    // TRISB = 0xFF; // default all GPIO as inputs
    TRISA1 = GPIO_OUTPUT; // red LED is output
    TRISB3 = GPIO_OUTPUT; // yellow LED is output
    YELLOW_LED = 0; // start with LED off
    RED_LED = 1; // start with RED_LED on
    timer_initialise();
    while (1) {
        if (time_count == time_threshold/2) {
            time_count = 0;
            YELLOW_LED = ~YELLOW_LED;
    return;
I am using MPLAB X IDE 5.40 with XC8 v2.41 compiler.
The results I get are:
  1. The yellow LED blinks at a frequency of 850 Hz instead of the 1 kHz I was trying to achieve
  2. The red LED remains on constantly instead of blinking at the 10kHz I was trying to achieve
Both were measured with oscilloscope and DMM.
I realise the objective is pretty benign but it's just an exercise I am going through to learn and practice basic concepts.
  • \$\begingroup\$ Could 1) be an off-by-one error? \$\endgroup\$
    – Hearth
    Jun 6 at 15:21
  • \$\begingroup\$ Ah! Could be! With prescaler at 1:2 you're right, I recall there should be an adjustment of 1. Let me try... \$\endgroup\$
    – RickyBoy
    Jun 6 at 15:29
  • \$\begingroup\$ I'd write that as an answer, but I don't think I can help with 2), so it'd be an incomplete answer. \$\endgroup\$
    – Hearth
    Jun 6 at 15:37
    \$\begingroup\$ Is this a chip where the comparator is active by default? If you want RA1 to be a digital I/O, you might try disabling the comparator...CMCON=0x07. Haven't used this chip, so am unsure - this addresses the constantly-ON RED LED. \$\endgroup\$
    – glen_geek
    Jun 6 at 15:55
    \$\begingroup\$ This is an 8 bit MCU and you use variables of type long, which need 4 memory read cycles to fetch the value. But the interrupt code may modify such a value in the middle of a read access of the main loop. Such variables must be declared as "volatile" and the access in the main thread must be surrounded by disable and enable interrupt calls. \$\endgroup\$
    – Jens
    Jun 6 at 17:53
When TMR0 overflows, its interrupt is triggered, while TMR0 merrily keeps incrementing every microsecond...TMR0 has already incremented some few # counts before it gets reset to its new value.
  • Since interrupts act like a CALL, TMR0 has already incremented by at least two at the beginning of interrupt routine.
  • Flipping the RED LED takes at least another microsecond, and increments TMR0 by another count.
  • Calling reset_timer() is another call - 2 more microseconds, and 2 more TMR0 counts
  • Actually writing the new value to TMR0 takes another microsecond.
There may be more microseconds lost if the interrupt routine saves W and flags. All these extra microseconds extend the time between TMR0 writes (which lowers the frequency)
In any case, you should likely change reset_timer()
    TMR0 -= TIMER_RESET_VALUE;
Or change the interrupt routine:
    time_count++;
       time_count = 0;
EDIT:
Subtracting a constant from a running timer can miss or add counts, depending on when the subtract actually takes effect. I cobbled up this interrupt structure in ASM (since I don't trust micro-compilers) to see if pipeline or other timing issues affect TMR0 period.
I would have guessed that TIMER_RESET_VALUE would be near 100 to interrupt every 100 microseconds. But subtracting a value of 97 resulted in 100us interrupt period - it seems that TMR0 stalls a few counts after the subtract...at least that's what MPLAB's Simulator tells me.
A compiled ISR may operate differently, requiring a tweak to TIMER_RESET_VALUE. If more predictable delays are required, the whole LED-flashing process would be better done in PWM mode with TMR2...using PR2 to set the period. NO ISR required to flash the RED LED. It is a more-complex thing to configure.
For some reason, Microchip thinks users prefer to use the two internal comparators, which over-rides the use of PORTA GPIO least-two-significant bits.
So if you want to use RA0 or RA1 as general-purpose I/0, you must disable comparator function by setting CMCON=0x07, rather than its power-on default of 0x00.
Multi-function I/O pins are a pain to re-configure, but add versatility. MPLAB X IDE 5.4 may do the reconfiguration for you, if you use all its configuration features.
  • \$\begingroup\$ Thanks for this answer, lots of very useful info. I wonder whether: a) the reset should be TMR += TMR_RESET_VALUE b) the reset should be the last line of the ISR I did this and I now have both LEDs only 1% off-target. (Agree about the use of PWM - this exercise was simply one for me to learn the use of timers and their interrupts - the ultimate application requires it) \$\endgroup\$
    – RickyBoy
    Jun 7 at 9:53
    \$\begingroup\$ RickyBoy - "-=" or "+=" as you please. When you leave home, do you count the kilometers from home, or kilometers to your destination? Consider code readability for someone else. Slightly safer to add/subtract TMR0 early in the ISR while its count value is low, to avoid potential math overflow if TMR_RESET_VALUE approaches 255. \$\endgroup\$
    – glen_geek
    Jun 7 at 12:28
  • \$\begingroup\$ Thanks very much \$\endgroup\$
    – RickyBoy
    Jun 7 at 14:47
I was able to load and run the OP's original project, and the simulator stopwatch shows the timer interrupt occurring at 133 us intervals. The yellow LED toggles with about 660-675 us. The PICkit3 is in the list of available debuggers.
This is primarily to see that the project will run using the simulator.
MPLABX IDE
  • \$\begingroup\$ Thanks to you I am able to use the debugger now. I feel I should share the code I now have (with all the great tips and advice I have been given) which works perfectly as far as I know. But being new to this forum should I submit it as an answer, or an edit to the original post? \$\endgroup\$
    – RickyBoy
    Jun 8 at 16:03
