I am checking a Nissan forklift wiring diagram and don't know what the rectangles with one and two diagonals are. I would appreciate any idea about this.
1\$\begingroup\$ they could be resistors of specified power ratings, check if the schematic says anything about it. \$\endgroup\$– HearthCommented Jun 18, 2023 at 21:19
2\$\begingroup\$ Nissan is known to use the symbol with the single diagonal line for fuses, and their position in the diagram would make that very likely. The ones with two lines might be wiring harness connectors. \$\endgroup\$– GodJihyoCommented Jun 18, 2023 at 23:58
\$\begingroup\$ @ GodJihyo. That makes lots of sense to me. \$\endgroup\$– HenryCommented Jun 20, 2023 at 20:02
\$\begingroup\$ @ GodJihyo You are right! They are harness connectors. \$\endgroup\$– HenryCommented Sep 30, 2023 at 6:54
Add a comment
1 Answer
Rectangle Symbol in Electrical Diagram
There are various symbols used for fuses and this is one of them: -
