One of my friends has a car patrol light. He wants to use a transformer to supply power. This light has two lightbulbs, 50 watts each. The front light is red and stays on, on the opposite side is an amber light that flashes.
We need to know what type of transformer we need.
Info: 12 V 50 watts x 2
  • \$\begingroup\$ What's the power source? Mains of some kind? Or something else? \$\endgroup\$ Commented Aug 21, 2023 at 5:26
  • \$\begingroup\$ This was mounted on a car many years ago. \$\endgroup\$ Commented Aug 21, 2023 at 23:03
I'm going on the assumption that, when you say "transformer", you mean a thing that you plug into the wall (AC power) and get 12V (DC power) out the other end. If so, the more accurate term would be "power supply". The term "transformer" specifically refers to the device that uses windings of wire around a core to convert one AC voltage to a different AC voltage. More stuff is required to get DC power out of it.
Based solely on the 50W solid + 50W flashing numbers, you'd need a supply that could handle the peak usage, 100W, when both lights are on. 100W / 12V = 8.3A.
However, there will be a relay causing the second bulb to flash, which will eat a bit more power. My guess is that it'd be safe to assume it's under 0.5A, but I would personally test the assembly with a multimeter while it's powered. Unfortunately, that may not be possible if the flash is fast and/or the multimeter is slow. The reading might not stabilize by the time the relay switches the second bulb on or off.
Skipping the manual power measurements, the whole thing is likely under 9A, but I wouldn't run it off a 9A power supply for two reasons: (1) It's not a good idea to continuously run a power supply at its maximum rated output. (2) There's a pretty good chance that the manuafacturer of the power supply was a bit generous in their rating. If you measure the voltage across the power leads and it dips significantly when both bulbs are on, then you're pushing the power supply too hard.
Using the assembly as-is, I'd probably use a power supply rated at 15A, at least. After a very quick look, they seem to be around CA$50 on Amazon and CA$30 on AliExpress.
I would most likely replace at least the constanly-on bulb with an LED to reduce the power consumption and heat generation (every Watt of inefficiency in an incandescent bulb is released as heat)*. If an LED wouldn't spoil the ambiance for your friend, the how-to would warrant another question, if it hasn't aready been asked.
Good luck!
*Edit: More accurately, every Watt of inefficiency in anything is released as heat. The reason LEDs are more efficient than incandescent bulbs is because less heat is released per quantity of light produced. And, ultimately, that light gets absorbed into some object and it too gets converted to heat. And friction -> heat. Etc., etc. And that's the depressing reality of entropy. Y'know what cheers me up? Pretty lights!
  • \$\begingroup\$ A power source to plug to an outlet is what I need.This is for my friend's man cave.It won't be used like everyday,just when hanging out with friends. I'll go for a 15 amp,12V power supply to be safe.These light bulb are sealed beams,they can not be changed to LEDs. \$\endgroup\$ Commented Aug 21, 2023 at 22:59
  • \$\begingroup\$ @CarlangasPeralta A worthy application indeed. Enjoy. \$\endgroup\$
    – Naptha
    Commented Aug 22, 2023 at 4:59
The patrol light has 2 lightbulbs that are 50 watts each. So the total wattage is 2 * 50 = 100 watts. The bulbs operate at 12V. To determine the transformer, we need to calculate the total current draw. Power (P) = Voltage (V) * Current (I).
  • For each 50W bulb at 12V:
    • P = V * I
    • 50W = 12V * I
    • I = 50W / 12V = 4.17 amps
  • With 2 bulbs, the total current draw is:
    • 2 * 4.17 amps = 8.34 amps
So based on this:
  • You need a transformer that can supply at least 100 watts of power.
  • The transformer needs to have a 12V output voltage. - It should be rated for a minimum of 8.34 amps of current capacity.
  • A transformer with a 12V, 10A (or higher) rating would be ideal to give some extra headroom.
  • You can use a standard 12V transformer made for lighting or other DC devices. Just ensure it meets the voltage, power, and current requirements listed above.
