My device runs from a USB supply, typical 5V, current typically 20mA, never beyond 100mA.
I want to add a fuse. The JFC0402-0500FS claims rated current 0.50A (perfect for this application) and a typical resistance of 500mΩ.
Since E=IR, I'm getting an expected voltage drop of 50 mV. Now, that resistance is at a full 100mA; perhaps the resistance is higher for less current, so let's double it to 100mV. Is that the correct voltage drop to expect?
Interestingly, the larger packages (e.g. 0603) had higher voltage drops, the opposite of what I'd expect from a resistor. I chose this package and this trip current to minimize the voltage drop.
