I'm trying to find the norton equivalent current and resistance for the circuit above, but this type of problem is stumping me. I'm used to having the voltage source and the first resistor in series rather than in parallel so I'm unsure what to do in this case.
I've tried using the normal method by first combining the 12V source and the (12 Ohm resistor in series with 4 ohm resistor = 16 ohm resistor) to make a current source of 0.75A parallel to a resistor of 16Ohms. Then I combined the 16 and 12 Ohm resistor to make a 6.86Ohm resistor in series with a voltage source of 5.14V. Then finally the 6.86 is combined with the 1 to make a 7.86 Ohm resistor in parallel to a 0.6545A current source.
So my calculations make it seem like the Norton equivalent resistance is 7.86 Ohms and the equivalent current is 0.6545A, but both of these are incorrect.
What mistake have I made, and how can I reevaluate the circuit?
