I have been looking at which TVS diode to select for a protecting a set of RS-422 driver lines, however I am struggling to understand how to choose them based on the diode capacitance. The signal will be 2MHz and be driven from a AM26C31IDBR quad RS-422 driver.
The first option I picked was this SM712, which is designed for RS-485. However, I noticed that the diode capacitance is 75 pF, which seems high however I am not sure what scale to use.
How do I calculate the maximum diode capacitance for a certain frequency signal? The lines will be 120 ohm twisted pairs
If I am correct, higher capacitance increase ESD protection but reduces frequency.
Thanks for any help
Edit: As requested here is how I will use the diodes
