Grounding lines to power LEDs, switch in electronic device
I'm self taught. My question concerns ground.
This is the bottom of a plastic device. Above, there is battery and LEDs. Positive feed (s+) enters south, at (A) it connects to line (s1) to a switch terminal (t1), and line (r+) to recharge port (p+). At (B) line (s2) from switch terminal (t2) enters to connect to line (s3) that connects to LED#1 pos. pad (#1+). LED#1 neg. pad (#1-) connects to line (s4) that connects to LED#2 pos. pad (#2+). LED#2 neg. pad (#2-) connects to line (s5), which connects to negative feed (s-) and line (r-) in area (C).
Lines (s+), (r+), (s3), (s4), (s5), (r+) are in channels. Copper lined?
Areas (A), (B), (C) -- copper lined?
(r+) and (r-) feed into isolated tubes. Copper?
(s3) runs from (#1-) tp (#2+). Ground issues?
Thank you for assistance. I am familiar with PCB. Did not know if grounding issues present in wiring up 'old school.' From responses, do not think it is. Greatly appreciate.
