Can i directly connect this chip to PC and how can i amplify it for increased range (NRF24L01)?
for more: http://www.semiconductorstore.com/cart/pc/viewPrd.asp?idproduct=765
No, the IC cannot be directly connected to a PC, as it does not have any means of communicating with the PC through any of the standard interfaces the typical PC supports.
Please also note that the particular IC linked in the question is clearly indicated as obsolete on the manufacturer's page:
This product is not recommended for new designs. Nordic recommends its drop-in compatible nRF24L01+ or for a System-on-Chip solution the Nordic nRF24LE1 or nRF24LU1+.
The nRF24L01+ or nRF24L01Plus is the direct replacement, which is also one of the recommended alternatives on the SemiconductorStore page link given in the question.
Also, the IC will in itself do very little for you: It needs to be used in a suitable circuit board, which will also need a whole bunch of other support components, to do anything meaningful at all.
The datasheet for the nRF24L01+ provides sample schematics of how the IC can be used to implement a 24 GHz RF transceiver.
Clearly, not a trivial matter of patching in some amplifier.
If the functionality of the nRF24L01+ is of interest, consider using a pre-built module such as this one from eBay ($1.42 including free international shipping):
For connecting it to the PC you will additionally require a suitable USB-connected microcontroller development board such as an Arduino, or some suitable USB to TTL adapter.
Edit:
To get a slightly better understanding of how to use the Nordic IC, please read this article: "Tutorial 0: Everything You Need to Know about the nRF24L01 ...".
Can you directly connect it? Obviously not. It doesn't have a USB, PCI, firewire, RS-232, or any other connector that would interface with anything on any normal PC. Can you build something to interface that IC and your PC? Yes, but it's a complex thing to do. The result will probably look something like this:
To amplify it, you'd need an RF amplifier specified for use at 2.4GHz.
