Well I am Working on a PIR occupancy sensor project and the issue is, it is having false detection on occasions like when an air conditioner or a fan is turned on, well I can't figure what to do?
1 Answer
As there is no physical difference between the heat from a human body and the heat from the heating system (they both emit electromagnetic waves at the same wavelength), PIR sensors cannot distinguish the two. There is one difference, though: a human moves about the room. Therefore, what you need to do is prevent the heat from the heating system from moving around the room. Or, better yet, switch to a different motion detector, such as ultrasound or microwave.
\$\begingroup\$ The problem is that the sensor is creating noise every time when a ceiling fan or AC is turned on. And it is very difficult to differentiate between the signal caused by human detection and the signal caused by these external factors. \$\endgroup\$ Commented Apr 6 at 4:54
