I bought two cheap monitors in a local shop. They are basically the same model, and both came with an ungrounded external power supply.
After getting a few shocks from the HDMI cable I realized it is outputting a constant voltage. I measured the ground casing of each cable coming out of the monitors with a multimeter and both registered around 1 V (it seems to be actually fluctuating a bit, or my multimeter rods are not very good).
The outlet where I plug my computer is grounded, so I think I can assume this current goes all the way to earth once I connect the HDMI to my computer. I had some instability problems before though, my computer seemed to be not giving the performance it should and I was getting frequent BSOD's. Long story short, I determined that the PSU was the problem, I replaced it, and the computer got back to normal. But I wonder now if this isn't damaging my computer on the long run. I also work with a Mac Mini that is not grounded (or I guess it has an internal PSU that should handle that), connecting these monitors to it makes the whole thing live and everything else that is connected to it. Any insight will be greatly appreciated!
Monitor models:
Monitor 1:
- Product Name: Athen V2L 21
- Model: PG-ATHV2L21-BL01
- Certifications: FCC, CE
Monitor 2:
- Product Name: Horizon Z21
- Model: MCR-HZN21-BL1
- Certifications: TÜVRheinland
PSUs (both are exactly the same):
INPUT: 100-240v~50/60hz 0.85A Max
OUTPUT: 12.0 V - 2.5 A 30.0 W
Certifications: FCC, CE, CB
The "certifications" I included solely based on what I saw on their back labels.
My AC is 220 V.
