As part of a university project I'm trying to produce a current through an inductor (610uH), that'll eventually be used as a solenoid. I'm producing this using a PWM voltage produced by a TI GaN inverter board (3PhGaNInv) powered from a bench-top power supply.
I'm having an issue that on the edges of the PWM, there is a huge spike in current through the inductor (measured using an in-line 8.9 Ohm current sense resistor). Note that I don't care about the current ripple at this point, just the spikes that occur when switching.
This seems to be caused by the bench-top power supply drooping, then overshooting back whenever the output of the inverter board is switched (see bottom graph). I'm confused as to why this is happening, as the schematic for the inverter board shows a 220uF and 3.3uF capacitor over the supply lines which I thought would prevent this.
I've tested this with three power supplies, including a DC regulated one, and the voltage ripple is very similar in all of them. Any ideas what's causing this, or how to prevent it?
