There is a connection between current and voltage.
Amps (A) is voltage (V) divided by resistance (R): A = V/R
And yes, the more voltage, and thus the more current it draws in an electric component, the faster it goes (for a fan for example) or the more the light is strong (for a led for example).
I have a step up inverter that steps up voltage...
For example this product
So it would be logical that more voltage pass on the out side of the socket of the transformer, the more current will be transmitted in the out side socket of the transformer...
But here we speak about the keep on the power, but why here its thus the inverse?
What's the relationship with my sentence: "the more voltage, and thus the more current it draws, the faster it goes.", in this case of a transformer? Why a transformer that steps up voltage delivers less current? Why do we keep the same power in this case?
Is it differs from a battery that "create" voltage and current from "zero"?
Why in this case there is conservation of energy? Because when current flows through a component like a led or a fan, more voltage pass though it, more current pass also.
