I have found multiple RS232 to RS485 converter dongles (from different brands, models, and makes) that do not need external power to operate.
Connect the RS232 DB9 on one side, and three wires for the RS485 out the other side, there is even a small LED in the converter that shows connectivity.
I assume (guess) the power comes from the RS485 side of things as the LED goes dark when I only have the RS232 side connected.
- Where is the power coming from to power this converter? (I assume RS485 A/B)
- How much current is available?
- Is there enough current to run a microcontroller (like SAMD21)?
- Is there a reference design for capturing power from RS485 or RS232?
Examples:
