I am self learning the use of pre-emphasis from The Open University courses, and it states the following:
The bandwidth of FM with and without pre-emphasis filter is the same, which is given by \$2(m+1)W\$, where \$m\$ is the modulation index in FM and \$W\$ is the bandwidth of the message signal in the unit of Hz.
[Quoted from Unit 4, ELEC S211,Fundamentals of Communication Technology, The Open University of Hong Kong]
The following explanation is also given:
Since the bandwidths of FM with and without pre-emphasis are both calculated by Carson's rule, the use of filter does not affect the transmission bandwidth of the signal.
However, I think it increases the transmission bandwidth since:
$$ m=\frac{\Delta}{W}=\frac{f_{d}A_{peak}}{W} $$
where \$f_{d}\$ is the frequency sensitivity in the unit of Hz per unit amplitude and \$A_{peak}\$ the peak amplitude of the message signal.
As you amplify the high frequency component of the message signal, the \$A_{peak}\$ increases and hence \$m\$ increases. This will certainly increase the transmission bandwidth as there are more sidebands now due to the increased \$m\$.
Is there something wrong in my reasoning?
