TLDR: Can USB packets be transmitted between host and device, even if a possible hardware problem exists as evidenced by a USB error -71
I am working on a custom board that uses USB 2.0 HS to communicate with a host computer. Previously, my computer was able to enumerate my device and start communication--however, upon receiving pre-fabricated copies of my board, enumeration no longer happens, and I'm presented with a USB error -71
When I plug my device into my computer, dmesg gives the following output:
[ 9058.933325] usb 3-4: new high-speed USB device number 22 using xhci_hcd
[ 9059.061745] usb 3-4: Device not responding to setup address.
[ 9059.269619] usb 3-4: Device not responding to setup address.
[ 9059.481349] usb 3-4: device not accepting address 22, error -71
Many forums that I've visited online blame device- or host-side hardware issues for the error mentioned above. However, this advice doesn't make sense to me in my situation, for reasons to come.
In an effort to debug , I've used Wireshark to capture USB packets being sent between the host and the faulty device. I've even compared the packets from the faulty device to working devices that use the same MCU I use on the board (for instance, a development board for the MCU) and the packets 'agree' up to a certain packet. Here are the outputted packets from Wireshark for the faulty board:
1 0.000000 3.1.1 host USB 67 URB_INTERRUPT in
2 0.000012 host 3.1.1 USB 64 URB_INTERRUPT in
3 0.000042 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
4 0.000087 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
5 0.000093 host 3.1.0 USBHUB 64 CLEAR_FEATURE Request [Port 3: C_PORT_CONNECTION]
6 0.000131 3.1.0 host USBHUB 64 CLEAR_FEATURE Response [Port 3: C_PORT_CONNECTION]
7 0.000136 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
8 0.000173 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
9 0.035198 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
10 0.035252 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
11 0.071208 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
12 0.071301 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
13 0.107180 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
14 0.107227 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
15 0.143176 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
16 0.143225 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
17 0.143337 host 3.1.0 USBHUB 64 SET_FEATURE Request [Port 3: PORT_RESET]
18 0.143378 3.1.0 host USBHUB 64 SET_FEATURE Response [Port 3: PORT_RESET]
19 0.211191 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
20 0.211248 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
21 0.211255 host 3.1.0 USBHUB 64 CLEAR_FEATURE Request [Port 3: C_PORT_RESET]
22 0.211295 3.1.0 host USBHUB 64 CLEAR_FEATURE Response [Port 3: C_PORT_RESET]
23 0.271315 host 3.0.0 USB 64 GET DESCRIPTOR Request DEVICE
24 0.271503 3.0.0 host USB 82 GET DESCRIPTOR Response DEVICE
25 0.271530 host 3.1.0 USBHUB 64 SET_FEATURE Request [Port 3: PORT_RESET]
26 0.271592 3.1.0 host USBHUB 64 SET_FEATURE Response [Port 3: PORT_RESET]
27 0.339156 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
28 0.339220 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
29 0.339228 host 3.1.0 USBHUB 64 CLEAR_FEATURE Request [Port 3: C_PORT_RESET]
30 0.339266 3.1.0 host USBHUB 64 CLEAR_FEATURE Response [Port 3: C_PORT_RESET]
31 0.815223 host 3.1.0 USBHUB 64 CLEAR_FEATURE Request [Port 3: PORT_ENABLE]
32 0.815280 3.1.0 host USBHUB 64 CLEAR_FEATURE Response [Port 3: PORT_ENABLE]
33 0.815548 host 3.1.0 USBHUB 64 SET_FEATURE Request [Port 3: PORT_RESET]
34 0.815590 3.1.0 host USBHUB 64 SET_FEATURE Response [Port 3: PORT_RESET]
35 0.870742 3.1.1 host USB 67 URB_INTERRUPT in
36 0.870758 host 3.1.1 USB 64 URB_INTERRUPT in
37 0.883203 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
38 0.883274 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
39 0.927234 3.1.1 host USB 67 URB_INTERRUPT in
40 0.927243 host 3.1.1 USB 64 URB_INTERRUPT in
41 0.951214 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
42 0.951273 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
43 1.159190 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
44 1.159250 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
45 1.175192 3.1.1 host USB 67 URB_INTERRUPT in
46 1.175196 host 3.1.1 USB 64 URB_INTERRUPT in
47 1.367190 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
48 1.367251 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
49 1.423167 3.1.1 host USB 67 URB_INTERRUPT in
50 1.423184 host 3.1.1 USB 64 URB_INTERRUPT in
51 1.575195 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
52 1.575256 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
53 1.575264 host 3.1.0 USBHUB 64 CLEAR_FEATURE Request [Port 3: C_PORT_RESET]
54 1.575308 3.1.0 host USBHUB 64 CLEAR_FEATURE Response [Port 3: C_PORT_RESET]
55 1.575313 host 3.1.0 USBHUB 64 CLEAR_FEATURE Request [Port 3: PORT_ENABLE]
56 1.575356 3.1.0 host USBHUB 64 CLEAR_FEATURE Response [Port 3: PORT_ENABLE]
57 1.575512 host 3.1.0 USBHUB 64 CLEAR_FEATURE Request [Port 3: PORT_ENABLE]
58 1.575555 3.1.0 host USBHUB 64 CLEAR_FEATURE Response [Port 3: PORT_ENABLE]
59 1.575566 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
60 1.575608 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
61 1.575613 host 3.1.0 USBHUB 64 CLEAR_FEATURE Request [Port 3: C_PORT_CONNECTION]
62 1.575655 3.1.0 host USBHUB 64 CLEAR_FEATURE Response [Port 3: C_PORT_CONNECTION]
63 1.575663 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
64 1.575704 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
65 1.611188 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
66 1.611251 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
67 1.647156 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
68 1.647212 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
69 1.683213 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
70 1.683272 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
71 1.719178 host 3.1.0 USBHUB 64 GET_STATUS Request [Port 3]
72 1.719229 3.1.0 host USBHUB 68 GET_STATUS Response [Port 3]
When I compared this output to that of a working development board, I noticed that the transactions take different directions around packet 31, when the host issues a CLEAR_FEATURE Request [Port 3: PORT_ENABLE]
. Then it almost looks like the host tries to restart the USB communication with the faulty board all over again, and eventually I get the usb error -71
in dmesg (strangely enough, not in Wireshark).
What I don't understand is something likely very naive: if device not responding to setup address, usb error -71
generally is triggered by a hardware issue, why is my device able to maintain USB communication with my computer as shown above? Wouldn't a hardware issue imply that no USB packets would be able to be sent?
EDIT
A detailed breakdown of the packets I received in the above Wireshark log are included in the following repo:
