Two led tapes of width ~1cm sit 1cm apart. Between them in the middle, there's an obstacle around 3mm thick. I want to connect the LED tapes with a flexible cable that goes around the obstacle. FFCs come to mind, but I'm not sure what's best. Do you have any ideas for alternative approaches? I discovered JST FFC Connectors in the Similar Questions section before making this post. Would a JST FFC approach be relatively feasible in a DIY project? Ideally, the cable should snap in and be easy to disconnect, in order to make the tape pieces modular and easy to replace. My LED tape is a bit dense (144 LEDs per meter) and has 3 pins as shown in the image. I may have to do something about the limited length on the edges, but my main concern is picking the right cable/connector approach.
(And apologies for the low-res picture & bad soldering)
As you can see, using regular wire takes up too much space.
